Originally Posted by TOM R
(Post 440827)
2 things
1) that 3 m tape sucks I used that on my in laws handicap ramp and is nfg we're, you also need to use contact cement for wood surfaces still been like 6 months and they are peeling followed all directions to the letter, only good when dry 2) that carpet runner vynil also sucks when wet, you will turn the roof into a slip n slide You could use paint then throw sand on it used it on a trailer worked OK cheap any experience with that no slip epoxy garage floor paint? probably the same results could be had with the medium thrown in the paint, I'm guessing. |
Yeah, why not some bedliner??
Originally Posted by fishEH
(Post 440838)
on it....hope I can find pink thank you very much |
Or paint and a packet of the grit Home Depot and others sell for adding to paint to make it slip resistant.
i think you had the right idea with the Home Depot rustolium garage floor paint, it will have no problem stick to the plywood and once you throw the speckle stuff down, it becomes slip resistance.
yep...well, i was set on bedliner, but reviews say no go on plywood. so i have 2 gallons of that homy d garage stuff in my trunk. I will slop it on today
| All times are GMT -5. The time now is 04:58 AM. |
