Wiper Blades 2000 Disco II
You can get cut to fit replacement rubber for the factory D2 blades at Adv Auto or Autozone with a metal alloy rib on it and slide it in. Also, found a source for inexpensive rear wiper blades.
www.rovahfarm.com
They have good prices on other parts as well.
www.rovahfarm.com
Have you tried your local Advance Auto (or other parts store) for Trico - Part 21-11?
Is 21" the size you would recommend? I'm picking up a set of D1 arms at the dealership in a couple days, and plan to grab new blades on the way home.
Also, the new arms will have new spring assemblies, right? Mine lost their tension before a bad snowfall, and the wipers would miss the bottom 1/3 of the windshield every time they would try to swipe. Not cool. Just want to make sure there aren't additional parts I'll need to order to do this the right way.
