18 inches rims for discovery 5 3l v6 tdi hse luxury
https://cimg9.ibsrv.net/gimg/landrov...4ebe79bb1.jpeg
Hi i'am actually in 20 inches rims and i would get 18 inches some of you knows if it's possible to put 18 inches rims on the disco5 3lv6 tdi of 2018 (258 HP) it seems brakes are biger and 18 inchs doesnt fit ! Thanks for your answers |
I think it depends which brakes you have too? Some eg HSE models have larger caliper brakes I believe. As above only some shapes fit so test before you buy...
I put the compomotive 18" from Lucky8. I have smaller brakes, and I had to grind 1/8 off rear caliper, which wasn't an issue at all.
look through my built thread. |
Hi gmfain, thank you for your answer, is this also possible if I have the big brake calipers?
Doesn't this weaken the brakes? |
Originally Posted by amplio
(Post 886552)
Doesn't this weaken the brakes? Grinding that small amount doesn't effect the strength or function at all. Good luck 🍀 |
