Originally Posted by CJ455
(Post 661582)
Does it make refueling on gas a bit more of a struggle? Since it may be hard to tell if the engine is off?
Originally Posted by vulturez
(Post 661587)
I have kind of gotten use to it. There is some logic behind it. For example it seems if you stop the car, put it into park and then remove your seatbelt and remove pressure from the break it shuts off. If you keep your foot on the break, it won't shut off. I would have to make a list of the identified conditions but I have started getting use to it and it is very obvious if you look at the console or the Touch Pro, as it says "Climate off" when it shuts the engine off permanently.
My wife still finds this very confusing. Sometimes it turns itself off, sometimes it's just the stop start and when she lifts off the brake the engine starts up again...
We tried to find the sequence of gear in park, foot off brake, undo seatbelt and open door. If you do them in the right order if turns off every time. But in real world driving when you do those together it can throw you At least on ours (2018) it's very clear when the dash display goes totally blank then it's fully off... |
Does the td6 have auto shutoff? If so I’m going to have to disable that. What an annoyance. It’s a diesel it doesn’t save anything and I wonder what it does to the power system |
My 2018 Td6 has auto shutoff. The auto on/off system is pretty easy to live with in traffic and has worked without consequence. As soon as your foot comes off the brake it restarts. When stopping and it turns itself off automatically and you intend to shut the vehicle down anyway, just put it in park, open the door, get out of the vehicle and take the key fob with you. It will stay off - at least mine has.
How is it the reasoning for not going with a td6 is the short trips yet the diesel has auto start/stop? |
What an annoying and useless feature. Surely must decrease battery and starter life, particularly with compression and rotating mass of diesel. I click it off when I fasten my seatbelt. I have closely monitored my fuel economy while using it and with it disabled, cannot see any relevant change.
Wonder why they decided to make it that way. Perhaps it's not a big issue though, if fuel economy does not noticeably get affected.
Probably some emissions number looks better in city driving with the feature, but honestly don't see the point on the D5 (especially the TD6). Hybrids make a lot of sense to do this, but not on a larger engine big SUV. Wish there is the ability to permanently turn it off. Haven't gotten the D5 yet, but knows it is going to drive my wife nuts.
It is for improving emissions and is a required feature to meet their emissions disclosures. Hence they cannot turn it off for you
It does make a meaningful difference in both petrol and diesel vehicles. Of course if you only do long freeway driving it won't make much difference - but it also won't operate so you shouldn't mind it. Around town it's very significant. You get used to it pretty quickly |
| All times are GMT -5. The time now is 03:42 AM. |
