360 Camera Not Working
2017 HSE Si6: It seems that 3 of my 4 cameras in 360 mode are not working.
The view shows the ground surface for 1 of them, and is blacked out for the other 3. Anybody else have this feature? |
Not seen that happen.
Do the cameras work when you select them specifically? |
No, they are dark when I select them. I've got an appointment to take it in next week. Update In-Control, and fix a seat belt that keeps grabbing.
Update on my inoperative 360 cameras:
They are fixed. It wasn't the cameras but instead a failing parking sensor module that wasn't sending correct signals to the cameras and caused 3 of them to be off. A side note: Prior to this, in traffic, if I pulled too close to the car in front of me, the parking sensors would trigger and come up on the dash. This was kind of annoying in heavy traffic. I thought it was normal, but now that they replaced the failing parking sensor, it no longer alerts me if I pull up too close to the car in front. It does give a warning if I pull up too close to a parked car or garage door but I have to be much closer than before. Today I noticed my gesture tailgate no longer opens with a kick gesture. It worked before my updates. Doesn't seem like it should be related but it must be somehow. |
Originally Posted by ponderosajack
(Post 690975)
I'm sure I have the paperwork. Will check tomorrow and let you know.
Thank you!
Here it is:
869123 Diagnostic Allowance 865496 Module - Parking Aid Camera - Replace 869093 Configure Parking Aid Camera Module 1 LR081454 Module - Parking This was done in May 2019 on my 2017 D5 HSE Problem has not reoccurred. I have had an entire blank display once but it fixed itself upon restart. |
