-   New Discovery V (https://landroverforums.com/forum/new-discovery-v-51/)
-   -   Coolant for Discovery 5 (https://landroverforums.com/forum/new-discovery-v-51/coolant-discovery-5-a-116300/)
RichardinFL Mar 7, 2023 03:03 PM
I need to buy coolant for my 2020 Discovery Landmark. My current coolant is Orange.
Could someone please advise (brand name, specs) or provide a link to which one I should be buying?
I was told This One would work, but I'm not sure as it says "GM Vehicles"
Thanks in advance!
LR disco 5 Mar 7, 2023 04:24 PM
As it states in the owners manual use Havoline XLC 50/50 and mix with water. I couldn't find any of that in Canada so I went to the stealership and paid about 38 Cad which is around 27 Usd which isn't bad.
RichardinFL Mar 7, 2023 05:30 PM
Thank you LR Disco for your reply.
Could anyone pls confirm if THIS ONE is also OK?
LR disco 5 Mar 7, 2023 05:37 PM
I wouldnt try Ive heard about it on other forums but I wouldn't try don't know how it would affect the engine but myy 2 cents
Donc98 Mar 7, 2023 08:59 PM
Thanks in advance!
That is the one I used but the premixed 50/50 when I replaced the water pump, thermostat, and radiator last year on my 17. Also use the same fluid on my lr4.
gmfain Mar 10, 2023 07:00 AM
another choice is Delo XLC
https://buy.chevronlubricants.com/Br...B&gclsrc=aw.ds
LR disco 5 Mar 12, 2023 06:44 PM
isnt delo for semi trucks??
gmfain Mar 13, 2023 02:56 PM
It is , but it is also XLC standard. I believe it would be fine.
I bet Pentosin make something too. I have not researched it.
Rover06 Oct 20, 2024 06:51 AM
My low coolant light went on in my 2018 Disco Si6. Reservoir was well below the min marker. Lady i called at the dealership advised to top it off and wait to see if it drops again, although she was not a service advisor and i'm waiting to hear back from my service advisor on whether to bring it in right away (which i'm leaning towards doing). Will report back if i get it checked out.
I topped it off with the below Peak coolant (pink) which seemed to be a direct replacement for the Havoline XLC factory fill:
aforarun Oct 22, 2024 06:41 PM
I bought two cans of 50/50 premix blue color Prestone Euro from Walmart . Seems to be doing just fine
