Cracked sunroof
My wife got in her 2018 Discovery HSE this morning and noticed that there is a large crack in the sunroof. There does not appear to be any sort of impact mark that would have caused this - has anyone experienced an issue similar to this?
Ouch, do you have a picture of the crack?
Don’t have one nor recall reading about a crack in the moonroof. |
Picture of the crack in the sunroof
https://cimg3.ibsrv.net/gimg/landrov...017438578.jpeg
It was difficult to get a shot where the crack really stood out without being under cover. Unfortunately there’s a crack in the stucco of the porte corchere above the image that makes it difficult to differentiate the actual crack in the glass. I’ve drawn a line around the actual crack. |
Originally Posted by edwingow
(Post 687180)
It is pretty easy to swap out though. Remove the trim pieces on both sides and remove the screw mounting the glass. Re-install and adjust |
Same thing here...
I have the same problem with my 2017 Disco. I opened the shade and looked up a few days ago and there is a crack going all the way across. Also no "star" pattern from impact or anything. I've had a lot of sun/moon roofs over the years, never had one break before. Did they fix your's under warranty?
Originally Posted by Disco5tv
(Post 704986)
I have a cracked sunroof too
I looked up the other day and found a crack in my sunroof that goes all the way across the sunroom. And when I look down on it from up top, it actually is worse as it runs along the edges all the way from rear to front. It doesn’t look like there is any external damage at all. I just so happen to have a 32k service tomorrow morning, so I will bring it up. Of course I would like it covered under warranty, but I am not holding my breath.
Originally Posted by longtrip68
(Post 721268)
Me too! Whilst stationary!!!
(Post 687180)
cracked sun roof
i opened my sunroof yesterday and noticed a crack across - all the way from one side to the other. There had been no impact or anything that would have caused the crack. I wonder is anyone has an idea of how much it would cost to get it fixed
