Dealer Tow Package install, programming and components question
2 Attachment(s)
Hello,
Hoping someone who has had the OEM tow kit (VPLRT0174) installed at the dealer might be able to answer a couple questions. I contacted my local dealer and they ordered in the kit needed, they did the install and say they completed the programming update.
Cannot comment on missing parts. I haven’t seen those parts on USA cars, but maybe I missed it.
camera doesn’t look any different when trailer is hooked up and you use turn signals a different symbol is illuminated on dash, but other than that no difference that I know of. |
I installed the kit myself and had dealer do the programming. The only insert I know of is a rubber plug that goes in the the which when you are not towing. As far as the opposite tail lights I don't see that being in the Disco. The hitch comes with a pre installed harness that just connects to an electrical connector under the bumper cover.
The camera is a different issue. I have never been able to get the center alignment line to come on. I know all else works because I get a message when I connect asking if a trailer has been connected. Also, I had to add some resistors to my led trailer lights so the Disco would detect it and show the trailer turn indicator on the dash. I have a 2017 HSE TD6 wit surround camera Maybe the early years dont have the trailer line option. |
My 22 was ordered with the tow package and I have the hard foam insert. I've removed it because from the shape of the forms/cutouts, it seems to be made to store the UK version of the removable tow ball, the gooseneck one. Also, the wasted space in the foam means there's more space to store things without it there. You can surely make a more space efficient one yourself, don't sweat it.
Originally Posted by n559br
(Post 818654)
The camera is a different issue. I have never been able to get the center alignment line to come on. I know all else works because I get a message when I connect asking if a trailer has been connected. Also, I had to add some resistors to my led trailer lights so the Disco would detect it and show the trailer turn indicator on the dash. I have a 2017 HSE TD6 wit surround camera Maybe the early years dont have the trailer line option. hope this helps |
That trick did it. I finally saw the hitch assist line following you guidance.
Thanks. |
| All times are GMT -5. The time now is 11:14 PM. |
