DEF Fluid Level
If you get a dealer to refill your DEF they have a machine that essentially vacuums out all of the DEF in the tank and replaces it with a pre-determined amount. I don't know why, but the do this to ensure accuracy in the amount put in. (can't they just put a gauge on it like fuel??)
If an owner refills, there's no way to know exactly how much is in there and apparently if you fill it up all the way so that it's flowing out of the top of the tube, it can cause all sorts of havoc with sensors within the system.
I actually freaked myself out the first time I refilled because I accidentally poured it in too fast and it backed up and overflowed. I thought I'd over filled it, but I didn't.
The reality is DEF is cheap, putting it in is easy and you just need to put enough in so that it reads you have a few thousand miles of range on it. Putting a couple of gallons in will easily get you 4-5k miles.
By the time the light comes on to add DEF, you will likely need a full 2.5 gallon jug since you will only have 1200-1500 miles until DEF is empty. Take the cap off, extend the hose from the DEF box/jug, and add slowly to avoid overflowing (push the hose into the top of the tank inlet). You can also use the funnel provided with your vehicle (mine was in the glove box) and it might help the refill process. DEF is cheap! Right now under $11.00 for a 2.5 gallon jug from Peak at Sam's Club. When you restart the vehicle (it may take more than once), you will note that the message to refill DEF is no longer showing and you should be good for another 3000+ miles. Super simple, cheap and easy.
RugbyOregon (12-06-2020)
Just curious as I'm considering a tune as well.
never had any on my Jeep. It actually cut down on maintenance issues significantly. In Texas it also didn’t have any issues passing state inspections either. I’m taking Mine in today for all the updates and a CEL that’s on the. After that might be installing one.
