DEF Fluid Level
Old 09-27-2018, 01:05 PM
lltt's Avatar
Land Rover Owner Information
The DEF tank capacity is 4.8 US gallon, remember seeing somewhere indicating dealer full refill is 8 bottles at 0.5 gallon each.
Old 09-27-2018, 02:02 PM
1979rover's Avatar
Originally Posted by ToiletDuck
how can you overfill it and what happens?
If you get a dealer to refill your DEF they have a machine that essentially vacuums out all of the DEF in the tank and replaces it with a pre-determined amount. I don't know why, but the do this to ensure accuracy in the amount put in. (can't they just put a gauge on it like fuel??)
If an owner refills, there's no way to know exactly how much is in there and apparently if you fill it up all the way so that it's flowing out of the top of the tube, it can cause all sorts of havoc with sensors within the system.
I actually freaked myself out the first time I refilled because I accidentally poured it in too fast and it backed up and overflowed. I thought I'd over filled it, but I didn't.
The reality is DEF is cheap, putting it in is easy and you just need to put enough in so that it reads you have a few thousand miles of range on it. Putting a couple of gallons in will easily get you 4-5k miles.
Old 09-27-2018, 04:21 PM
Black 18 Disco's Avatar
By the time the light comes on to add DEF, you will likely need a full 2.5 gallon jug since you will only have 1200-1500 miles until DEF is empty. Take the cap off, extend the hose from the DEF box/jug, and add slowly to avoid overflowing (push the hose into the top of the tank inlet). You can also use the funnel provided with your vehicle (mine was in the glove box) and it might help the refill process. DEF is cheap! Right now under $11.00 for a 2.5 gallon jug from Peak at Sam's Club. When you restart the vehicle (it may take more than once), you will note that the message to refill DEF is no longer showing and you should be good for another 3000+ miles. Super simple, cheap and easy.
RugbyOregon (12-06-2020)
Old 09-27-2018, 05:24 PM
ToiletDuck's Avatar
yea I just don’t get the whole overfill thing. In my Jeep I just topped it off. You can buy it at Walmart here for like $7.00 for 2.5 gal if you with some unknown brand but it still has to meet spec. I’m going to be tuning mine anyway where it won’t need it.
Old 09-27-2018, 08:39 PM
vulturez's Avatar
Any idea what the full level miles is? Checked mine today and show ~4,5k
Old 09-27-2018, 10:26 PM
ToiletDuck's Avatar
Sounds about right per the manual.
Old 10-01-2018, 11:24 AM
1979rover's Avatar
So if you tune it, it won't need DEF? Are there any consequences for that?
Just curious as I'm considering a tune as well.
Old 10-03-2018, 11:23 AM
ToiletDuck's Avatar
never had any on my Jeep. It actually cut down on maintenance issues significantly. In Texas it also didn’t have any issues passing state inspections either. I’m taking Mine in today for all the updates and a CEL that’s on the. After that might be installing one.
aemnky606
11-14-2017 02:14 PM
Externet
09-20-2014 07:23 PM
rbaaddison
09-27-2010 07:59 AM
Jerover
08-21-2008 08:00 PM
SonicJunior
Defender
09-26-2006 12:31 PM
Quick Reply: DEF Fluid Level
