First servce?
I look on the instrument panel, with ignition on but engine not running. It is under Vehicle Information menu and called service information or something like that.
Disco V (02-27-2019)
Thanks...I just did that and was able to view the service info.
Why it isn't available while the car is running is a mystery.
It said 10,000 miles.
Seems like this is an interval that someone set...not one that the vehicle determined based on mileage, driving style, etc.
Is this correct?
Seems like some of the folks on here have a service indicator that appears to be a bit more dynamic...changing from day to day based on conditions.
There was an oil level option in there as well, but when I clicked on it, it said unavailable.
I'm surprised there isn't more service information available than a preset 10,000 mile mark.
This is no more useful than the sticker that Jiffy Lube affixes to your window.
Is this correct?
Is this correct?
Is this correct?
Land Rover Owner Information
To check the oil level you need to run it till it is at operating temp. Then turn it off and let it sit for a few minutes. Turn on ignition, but don't start it. You should then be able to check the oil level. It is similar to checking the oil level with a dip stick, get to op. temp, turn of engine and let it sit for a bit and then check while engine is off.
I added some links that may help.
Oh...so the 10,000 isn't indicating that I need to go in for service when I reach 10,000 miles...it's indicating that i have 10,000 miles remaining before I need to go in for service. I'm sitting at approx. 4,900 right now.
So the miles indicated will change as the days, weeks, and miles go by...correct?
So, 15,000 miles for the 1st service...does that sound about right?
I still think 15000 miles is way too long for a first service. But that is what the factory says.
I need to see if I can find a reputable independent shop here in Norcal, would prefer a full drain vs extraction of oil on some services.
