Will 19" RRS wheels fit?
Anyone know if 19" RRS wheels (235/65 r19) will fit a D5 Diesel w/7 seat air suspension?
Looking for a set for snow tires and these are for sale on CL close by me. Thanks |
Probably would work, but the offset differs by a few mm:
https://www.wheel-size.com/size/land...0-si6-eudm-335 vs https://www.wheel-size.com/size/land...ge-rover/2019/ also see: https://landroverforums.com/forum/ne...67/#post704626 |
Thanks Daredevil.
I did some digging and the Land Rover part # for the wheels is lr037792. It’s 19” x 7.5” with 45mm backspacing. Which is 1 inch narrower and shorter and 2mm shorter offset. I’m concerned about fitting over the rotors and rubbing due to the smaller size. Anyone running these size rims on a D5? |
There is a 7.5Jx19 ET39 option for the Disco, so you should be fine.
| All times are GMT -5. The time now is 05:49 AM. |
