Discovery 2 hard brake pedal
Hi. Just changed the fuel pressure regulator on my 01 TD5 disco. While driving after I had to stand on the brake pedal to stop. The brakes work fine at speed! I've checked the vacuum hose at idle; 18" pressure. So doesn't seem to be pump problem. No fluid leaks from master cylinder. I'm seriously stuck! Any help greatly appreciated.
welcome. How does the pedal feel with truck stopped. That is, is it something that happens with motion?
The pedal seems very hard when engine
Originally Posted by freedisco
(Post 616044)
Um. huh. If you changed the fuel pressure regulator, did that raise the engine idle? If the engine is running fast, that will make for a hard-to-stop situation.... Hope you already got it fixed!
