Intermittent full beam tell tale dashboard light MOT fail!
Hello all, first post and hoping for some help please!
My Y plate Discovery Td5 series 2 has failed it's recent MOT due to an intermittent tell tale full beam warning light in the dash (full beam and dipped headlights work fine, not affected). When you pull the lever stalk on the steering wheel towards you (to flash or switch to full beam) the blue dashboard light comes on very briefly (flickers once) and then goes out again. Likewise if you put the full beam on permanently.
To try and solve this issue I have so far done the following:
1. removed the light/indicator switch unit, opened it up and gave it a good clean with contact cleaner and refitted it. This appeared to briefly solve the problem but then reverted to flickering again..
2. replaced the light/indicator switch unit with a brand new one however this did not have any effect at all - same problem.
3.removed and replaced the bulb in the actual dashboard and checked the contacts in the bulb holder are secure - again no improvement.
I've run out of ideas and just wondered if you have any ideas about what to try next please? I was wondering whether it might be a relay, but am not sure where to start looking? Many thanks.
Er, no! The blue dashboard light should remain lit for the duration you have full beam in operation. Mine flickers on briefly and then goes out, hence the MOT fail. Thanks
charlielr2
02-24-2010 06:51 AM
wantstoknow
07-14-2009 11:12 PM
LR4LIFE
11-06-2007 10:23 PM
v8 bob
06-30-2007 04:52 AM
