Leaky window
Leaky window
I brought my newly purchased range rover to the dealer because I found water on both my frond floor mats and they told me my A/C is leaking onto my floor so they cut those lines and said all set. Today water again on my floor mats...I hate going to the dealer for anything. Can anyone help me find someone that can work on my rover an know what they are doing? I live in Saco,Maine
Your non-dealer local mechanic can deal with this, the AC drains could be plugged up. The drains are on each side of the transmission tunnel, and look like a small hole with an x across it from the underside. Insert a thin wire or piece of the stiff plastic material used for "weed eaters" to knock out clog or insect nest. You would not cut the lines, then they would always leak.
