clutch gone under 30k miles
Have A evoke, ex demo, had for 16 months with one service. 29k Miles but land rover will Not honour warranty as say driver error due to eccessive heat damage Not component. Has anyone else had this? Dont tow or do offroad etc.
Originally Posted by timrice
(Post 498375)
Even an Evoque is designed for offroad use, maybe not constant rock crawing, but, it should cope adequately with 50% offroad use as they advertise it as an offroad vehicle. If LR make a towing kit for the Evoque it means it's designed for towing within the stated spec weight limits. I'm no fan of the Evoque but it should perform better than that so don't let the stupid 'bar stewards' off the hook too easily. |
update
Thanks for your info. Had a friend look at the clutch they took out and agrees only heat marks. As i drove it 100 Miles to get it back to garage and wasnt slipping, Why did they replace. They did Not road test either!
Most companies consider the clutch a wear item like brakes or tires. Not saying I agree but that is normally the case.
(Post 499670)
It's probably why I will only buy autos now, manual boxes and clutches with stop/start town traffic don't go together. :rolleyes: |
I still have the original clutch in my 72 MGB with nearly 100k miles on it and the clutch is fine. Throw out bearing is getting grumbly though.
It is very much dependent on how you drive them. |
If it wasn't slipping what were the symptoms?
you bought a DEMO do you really think the salesman gave a crap about the clutch? they beat that car to within an inch of its life reconditioned it and sold .
