04 Range Rover Hse cooling pressure build up
Few months ago while I was driving, I realised that the water gauge pasted the 1/2 mark and it's close to 3/4 but has not reached the red line. I pulled over quick.Checked and found out the cooling plastic bottle cracked and it caused the car to overheat. I replaced the bottle and tested and seemed at the time everything was ok. The next day when I was driving i realized it was passing the 1/2 mark. I pulled over again and noticed that small hose that goes on the back of the head was busted. I replaced the hose and talk to mechanic who works on rovers. He told me that these engines even thought that i didn't overheat all the way to red the head gasket goes bad and there might be a pressure build up in your cooling system. He told me to check the cooling to see if there is pressure. I opened the cap few times and i realized that there was pressure in there. I was ready to take the head out. Drove after that few times and seems the problem went away. I checked the cooling and seems to me that there is no pressure, plus no hose problems. What do you guys think happpened and am I ok to take a long trip with the car? I am afraid to drive the car for too long. Forgot to add that each time i changed a part i took the air out from the cooling system so there was no air in the system. An after all this engine runs great and no check engine light.
If you did not severely overheat the engine, you are probably ok. The mechanic might be mixing the BMW and Rover V8 up. The rover v8 does not take overheating very well. The BMW engine (yours) is a more rugged motor and should be fine so long as it wasn't red lined for an extended period of time. How many miles are on it and when was the cooling system last serviced? If you are 100k or close to it, you might need to start replacing the radiator, hoses, thermostat, water pump, etc. Another thing, the cooling systems on rovers are pressurized, they are supposed to be. Over pressurization can be caused by many things, including the head gaskets. However, I would test other components before ripping the engine apart.
ambishop
Audio/Visual Electronics
12-13-2006 04:58 PM
