Can I place a 4.6 crank in a 4.0 block?
The ecu does not need to be swapped. The becm needs to be reconfigured for a 4.6 engine. Which is a simple as checking a box on a computer. Granted you have that computer... The swap should work. BTW, what year of rover do you have? It makes a difference. From what I've found, the bosch blocks are not the same as gems.
1999rover
02-17-2014 01:41 PM
GROVERDISCO
12-22-2012 06:44 PM
mouse
05-18-2012 12:25 AM
JBEGIN
06-27-2009 12:38 PM
