loose coil
Old 02-21-2011, 09:49 PM
roversprings's Avatar
Default loose coil
Getting ready to change out my spark plug wires and while reaching back to see if I could reach the coil I noticed that it moves up and down a bit like the bolt(s) holding it in place are loose? I can't see back there so I was wondering if the coil should be solid in place or if there is a system that holds it a bit loose in place. If there are bolts that have vibrated loose over time I hope I can tighten it back up once the wires are removed, any thoughts?
Old 02-21-2011, 10:50 PM
handsome rob's Avatar
The coils should be solid and not move up and down. It sounds like it is just loose and needs to be tightened.
trialrun
11-11-2014 08:41 AM
b_woodroaster
11-05-2010 08:54 AM
robot808
11-18-2009 11:10 PM
rphotographer
04-23-2007 11:10 PM
Aimee
04-04-2007 11:17 PM
Quick Reply: loose coil
