Reset after Check Engine message P38
Old 11-05-2009, 09:19 AM
faversham's Avatar
Default Reset after Check Engine message P38
I believe I triggered a "Check Engine" dashboard warning by sending in a wrong code w/ an incorrectly programmed remote control. I detect nothing wrong in my 1996 P38 4.6. How do I reset the computer to get rid of this error message? Thanks,
Stuart
Old 11-05-2009, 09:42 AM
Baylink's Avatar
"sending in a wrong code with an incorrectly programmed remote control" *what*? :-)
If you mean "keyfob", it ought to just be ignored.
If you mean "OBD attachment", I can't think of any way that one of those should be able to *set* your MIL, but in any event, it should be able to read and clear it.
So, what *did* you mean, exactly? :-)
Old 11-05-2009, 10:02 AM
LRScott's Avatar
... that is a bit odd, I guess its possible since its a rover. What code are you getting? Have you plugged an obd scanner into it? You need an obd scanner to reset the codes and check engine light. Usually you can take it to autozone and have them plug one of theirs in for free.
Old 11-05-2009, 10:14 AM
faversham's Avatar
Sorry, I meant keyfob, not remote control. I can't think of any other symptom.
Old 11-05-2009, 10:19 AM
Baylink's Avatar
I would not expect that the truck would do anything with an unrecognized keyfob but ignore it.
I'd recommend, as others have, taking it to a local Autozone or similar parts store; most have an OBD-2 scanner which they'll plug into it and read off the trouble codes for you for free -- Autozone in particular has all the codes in their register system and will print you a descriptive slip about the code and its meaning (or at least, mine did :-).
lornecci
10-14-2019 04:38 PM
FlyingZebra34
02-22-2014 05:39 PM
coleman1
02-17-2011 04:43 PM
ajordan_0012000
03-03-2007 05:57 PM
Quick Reply: Reset after Check Engine message P38
