RRC/d1 lift setup on p38?
Old 09-16-2017, 09:33 PM
Manbeer's Avatar
Default RRC/d1 lift setup on p38?
Am in the midst of simultaneously parting out my d1 with a terrafirma 3" lift and fixing up a 97 vitesse. I am curious if this shock/spring combination will work on the p38 or if it is much different. The previous owner already did a coil conversion so that aspect is taken care of, it would be a straight up shock/spring swap. I am aware that the p38 is probably 700-800 lbs heavier
Old 09-17-2017, 08:00 AM
Received 1,464 Likes on 1,195 Posts
I think if memory serves it will all work but the front shocks. I think they have different mounts than the d1. Of course with the conversion kit they may not
Old 09-17-2017, 10:38 PM
Manbeer's Avatar
Thanks for the input, I guess I will bite the bullet and order all new shocks and keep the springs if nobody buys the lift kit as is. Otherwise I'll find something properly suited to the p38. The tires are not the best and when I went to look for a brush guard, the local boneyard has a set of nice 70% new Cooper discoverer at3's in 265/70/18 for 160 so it seemed like it could work.
Old 09-18-2017, 07:05 AM
I'm running that size on the LR3 and they are a very tall 32" Great tires for that price though.
xftype
04-06-2023 10:08 AM
401Rover
04-05-2016 03:30 PM
WNYErikDiscoII
11-07-2013 09:32 AM
Lincoln Tarantino
05-02-2012 11:20 AM
Paul Grant
36
03-14-2012 07:59 PM
Quick Reply: RRC/d1 lift setup on p38?
