Shaking while driving
Old 10-17-2013, 05:22 PM
Bassmaster's Avatar
Default Shaking while driving
I have a 1997 Range rover with 130k miles. When I accelerate it begins to shake. And after I get passed 50mph it starts to really shake and the steering feels a little loose. I feel like it's the ball joints but does anyone else have this problem?
Old 10-18-2013, 02:35 PM
95RoverLWB's Avatar
A ball joint could be the problem. Jack up the tire, grab onto the front and back of the tire, "jiggle" it back and forth. Look/feel for play.
Rock stuck in tire?
Tires out of balance?
Tire warped?
These all happened to me, and they all fee a little different.
Old 10-22-2013, 07:13 AM
drowssap's Avatar
up & down for ball joints, side to side for tie rods. also check the steering shaft under the hood I had to replace mine in my 90rrc the u-joints in the shaft were gone.
Old 10-22-2013, 08:37 AM
binvanna's Avatar
grab the panhard rod and shake it forcefully to check the bushings for play
Old 10-24-2013, 02:48 PM
Bassmaster's Avatar
The bushings look fine, and the guy i bought it from did say the tie rod ends need to be replaced. I just got them in. Now comes the fun of putting them in
Old 10-25-2013, 06:04 AM
drowssap's Avatar
the tie rods are real rather easy, soak them with a good penetrating oil the night before.
Old 10-26-2013, 08:06 AM
Bassmaster's Avatar
Will do, I will keep you guys updated
Old 10-27-2013, 07:56 AM
Bassmaster's Avatar
What kind of penetrating oil would you recommend?
Old 10-27-2013, 03:37 PM
Bassmaster's Avatar
Would KY work?
Old 10-28-2013, 10:53 AM
95RoverLWB's Avatar
WD-40, PB Blaster, CRC. Every one has a favorite.
And KY would not work, maybe if you wanted to condition the leather!
Quick Reply: Shaking while driving
