Range Rover Classic Interior Trim Removal **advice needed**
Hey everyone, so I am in the process of adding some sound insulation to our RRC and I have gotten 99% of the interior removed without a problem however I am stuck on the plastic covers for for the rear seat fold down mechanism. Could anyone lend me some knowledge on how to get them to break loose? I have removed the two screws on the outside of the housing but it seems to be attached in the top corner section. I've attached a few images to help better explain where I am hung up.
Cheers,
Brock-
Cheers,
Brock-
AtlasK (01-28-2019)
AtlasK (01-28-2019)
Just gently pry the cover up from the bottom, then grab the sides of the cover and pull outward.
That's the way I've done it many times.
You can also spray some WD-40 through the top release button hole. Could help if the plastic is stuck to the metal latch body.
Here are a few good looks at what you're working with.....there's just not a lot going on.
AtlasK (01-30-2019)
niceflipflop
05-23-2023 09:56 PM
Markmetzger9494
08-15-2016 08:48 AM
