AC odor/ AC drain
Mildew smell from AC first step to make sure drains are not blocked system is draining from one spot. Is there one drain on Evoque or two?
If you only see one on pass might be it. Parts store sells a can of odor remover you spray into vents and A/C intakes. Find your cabin filter and change. Spray A/C intake while running A/C and use as much of can as possible. BG makes a good one but you have to find a dealer. Leave windows down to let air out when done.
What year is your Evoque? There was TSB regarding smells coming from the A/C due to the glue resin used for bonding the unit with RR Sports and there might be one for the Evoque as well. Check with your Land Rover dealership
sm
Thankfully I have not experienced this odor your speak of? but good to know about the glue resin for the future... didn't know that. Thanks
Locating intake for AC
Where is the air intake located on a 2013 Range Rover Evoque for the AC or outside air?
Originally Posted by Jagfixer
(Post 473553)
