2012 Rover Fuses
2012 Rover Fuses
Where can I find a diagram for a 2012 Range Rover ?? F20 in the engine bay is pulling power when it shouldn't. Can't figure out what it goes to. Thanks.
Update :
Just wanted to make a quick write on a 2012 L405 Supercharged . Battery wouldn't hold a charge for more than 12 hours sitting. If left alone long enough the battery would drain flat to barely readable on a meter. Checked for draw on most circuits with no luck. Checked grounds and nothing
Friend over at Land Rover told me to change the fob settings so when you hit the unlock button, the driver's door only unlocks. Second hit of the btton does the rest.
Battery is now holding a charge for about a week vs half a day.
Best of luck.
Update :
Best of luck.
nelsontod
05-15-2012 10:25 AM
xXDoublemanXx
09-25-2011 12:03 AM
