L322 windshield washers not working
Hi, my 04 L322 windshield washers will not spray and it does not appear to be the fuses. Neither front or back washers are working. Checked fuses but they are good. I had the hood open in a workshop mode, could this have pulled something loose? Also does anybody have a diagram of the spray system so I can check connections?
Thanks, Michael 04 L322 92k 05 LR3 133k 13 L320 60k |
Yes when you open the hood all the way you can yank on those hoses on the drivers side of the hood. Also check at the water bottle itself, pull the fender guard (black plastic thing held in with a million screws) and check the bottle itself. Could also be the stalk on the steering wheel.
I have a 2007 L322 SC. Try checking your codes and clearing them with a Gap tool or similar. I had the same issue and that solved it. Not sure why the code popped up in the first place but you know...Rover.
