-   Range Rover P38 (2nd Gen) (https://landroverforums.com/forum/range-rover-p38-2nd-gen-56/)
-   -   1997 P38 Engine Disabled Code! (https://landroverforums.com/forum/range-rover-p38-2nd-gen-56/1997-p38-engine-disabled-code-124097/)
karlward96 Nov 25, 2024 03:14 PM
I recently purchased a 1997 Range Rover P38 with 148,000 KMs. Overall in very clean, driving condition. I wanted to use it as my winter vehicle!
After a month of ownership, and 1000kms (600 Miles) later i went to open the vehicle and it wont start! It says engine disabled. I have the key fob, but it doesn't work! I replaced the batteries, its still dead!
I have purchased some used Key Fobs, can these be used? I need help here. I understand it would be much easier if my Key Fob could talk to the vehicle. I reached out to my Land Rover Dealership, (Car didnt come with security Code) and they wont tell me the code, and they cannot get Key Fobs for this vehicle.
The only thing that has changed when I unlock the car, it only unlocks the drivers door now, and not the other doors.
Needing help Team. Thanks.
Harvlr Nov 25, 2024 09:28 PM
The P38 won’t accept other fobs. My suggestion would have been to unlock it with your working fob. My next suggestion would be to enter the EKA code via the driver’s door key. There are some good YouTube videos on entering the EKA for the P38.
Harvlr Nov 25, 2024 09:30 PM
I see you’re in the US. Most NAS P38’s have 1515 as the code.
Harvlr Nov 25, 2024 09:34 PM
There is also a time delay. If you’ve just done something to make it think you’re trying to steal it, you need to wait something like 20 minutes before trying EKA. I’m fairly sure that doing the EKA procedure correctly will fix your issue.
yoni55 May 5, 2025 08:21 PM
alarm and security
installed yesterday a new 12V battery. car started geat did not use the FOB ,as the car is parked in doors
UNTIL THIS MORNING
my 2001 P38 FOB is not recognised by the car.
will not open doors.
when opened with kay the alarm goes off and the car will not start
1. disconnected the battery overnight
2. used the 1515 code
3. Range rover in Brampton( ontario) could not help..stated the car is too old :-(
any advice ? im desperate ...
call me any time at +1 647 529 9276 ( ontario canada time zone)
Jonathan
Harvlr May 5, 2025 09:07 PM
Presumably you followed the instructions for entering the EKA to a tee. Yes 1515 is the EKA for most NAS P38’s. Sometimes you need to wait 20 minutes or so before entering the code.
Harvlr May 5, 2025 09:10 PM
Also, it is possible that the EKA has been disabled with a Nanocom or Testbook. Some people think they are doing themselves a favour by disabling it. It means that you can’t use it to re-enable your car. Do you have access to a Nanocom?
Harvlr May 5, 2025 09:14 PM
There’s a used Nanocom for sale in the Marketplace section, but it’s licensed only for a D2. You would need to buy the Unlock for a P38 and the Green Cable for the P38, so it might not be worth getting the used unit.
