-   Range Rover P38 (2nd Gen) (https://landroverforums.com/forum/range-rover-p38-2nd-gen-56/)
-   -   99 rover will not reverse (https://landroverforums.com/forum/range-rover-p38-2nd-gen-56/99-rover-will-not-reverse-97797/)
slee Dec 3, 2019 10:39 AM
hello all !
here's the issue at hand:
99 range rover 4.6 hse
reverses at a snail's pace, if at all (feels and sounds more like it's in neutral)
showing code 20 "gear ratio monitoring (4th gear)
also showing code 5 "lock up clutch monitoring"
all else fine.
had just passed state inspection two days prior to the event.
mechanic said it was a transmission problem and referred me to someone else.
i'm wondering if it's the xyz switch and cable alignment more than anything else.
or, could it be the transmission ECU ?
the car has 105K miles on it and has always been impeccably maintained.
thoughts please ?
many thanks in advance.
