-   Range Rover P38 (2nd Gen) (https://landroverforums.com/forum/range-rover-p38-2nd-gen-56/)
-   -   P-38 electric issue (https://landroverforums.com/forum/range-rover-p38-2nd-gen-56/p-38-electric-issue-89830/)
koimaster Jun 4, 2018 06:29 PM
P-38 electric issue
Just parked the l322 and got the old P-38 up for the summer time. As is typical for this truck I have owned for 20 years now there is always an issue.
Right now the center console switches do not work. Cannot get the mirrors to move nor role the windows up and down. Anyone have any ideas before I run this off a cliff?
Fastercat Jun 5, 2018 06:10 AM
Did you check the fuses?
koimaster Jun 5, 2018 11:11 AM
I did check them. According to my manual it is fuse #22 in the interior right side. 30 amp fuse and it looked good. Thought it might be something else like a relay but the manual is pretty limited.
Fastercat Jun 5, 2018 03:01 PM
If you have or can borrow one use a test light and see if there power at the fuse.
Jim Geisler Jun 6, 2018 03:52 PM
I had to buy that center unit with all the switches and replace it and all worked again.
koimaster Jun 15, 2018 12:09 PM
Really? Crap that is a drag. Apparently there is no power to the switches but if I put the rig into reverse the mirrors change to backup mode.
Blofish Nov 2, 2018 05:16 PM
Had the same problem with fuse #22 every once in awhile would pop the fuse. Found the puddle lights at bottom of the doors witch I didn`t know were there had fallen complete apart and wires were causing a short in interior lights. I changed my lighting to LED and could not figure out where the other bulbs belonged thus the puddle lights hard to new and pricey a little solder and plexi glass they look and work great.
