Transmission Range Fault, Engine Fault, HDC Fault, Parking Brake Fault
Hi Gurus,
Please help. I am new to LRs, so I have this project car, a 2006 RRS with shy of 70K miles. It was flooded during hurricane Harvey (A little above the interior floor). I am having a couple of lights on the dash and I help diagnosing this faults so I can fix them.
First of all, I am having a parasitic draw. (I am suspecting due to the starter being bypassed and hot-wired to a button that I push on to start the car after I turn the ignition to position II, Though I may be wrong)
Here are the faults I see in the instrument cluster/message display:
Transmission Range Change Not Available
Engine System Fault
Transmission fault: Limited Gears Available
Parking Brake Fault (Parking brake sometimes engages, and most times does not disengage until I keep trying for a long period of time)
HDC Fault System Unavailable (This shows up as soon as the terrain response selector indicator light goes off)
Finally, there us a big "E" on the gear selector indicator
I would appreciate if I could get help with this. I am in the DFW area.
Edit:
Here are the codes I have pulled from the vehicle using iCarsoft i930.
Transfer Case Module codes:
U0126
U0101
P0561
P0562
U0100
U0155
Parking Brake Module Codes:
U0122
U2002
Steering Angle Sensor Module Codes:
U0300
Instrument Pack Module Codes:
U0001
U0010
U0100
U0101
U0102
U0132
U0182
U0159
U0127
U0138
U0184
B1A00
B1A87
B1A00
Air Suspension Module Codes:
U0416
U0100
U0126
U0101
Others:
P0036
U0101
P0071
Engine System Fault
Edit:
U0126
U0101
P0561
P0562
U0100
U0155
U0122
U2002
U0300
U0001
U0010
U0100
U0101
U0102
U0132
U0182
U0159
U0127
U0138
U0184
B1A00
B1A87
B1A00
U0416
U0100
U0126
U0101
Others:
P0036
U0101
P0071
kbarker27
10-13-2023 04:03 PM
JeroPot
LR4
02-28-2022 03:52 AM
06Range
05-08-2013 09:01 PM
