Tire pressure light, vehichle fault (system shutting down), parking brake lights on,
I have a problem with my 2007 Range rover Sport (RRS) HSE. The tire pressure lights come and go off, the parking brake light is on, and I get this message "vehicle fault, system shutting down (at times when I drive; the doors would unlock, any electronic --radio, GPS-- goes dead, hazard lights come on but car continues to run and the system eventually comes back after 1-3 minutes). I took it to a RRS dealer and he said, so many faults were coming up, making it difficult to pinpoint the problem. I suspected the instrument cluster (IC) is bad (based on my reading) and the RRS dealer told me if that is the problem, a new IC needs to be made in the UK specifically for the car and the mileage. I have question, has anyone every changed an IC in the US using a used one? Is there a mechanic you would recommend around MI, IL (Chicago), MN, and WI area? The dealer told me that a used part will not work for a RRS. Thanks
They are correct, the instrument clusters can not be swapped from car to car.
I wouldn't be too sure thats gonna fix everything. TPM module and park brake module failures are common on those. |
Thanks Maxx. I am an appointment with a mechanic in two weeks. Now the car won't start at all.
Ebbie |
Ebbie |
