Fan turns on after Engine off
I just purchased my Velar 2.0 250HSE, and noticed Fan turns on after engine off like a plane fan for 1-2 max and than turns off slowly. Is this normal behavior? |
Many vehicles will run the cooling fans to continue to drop the coolant temp for a short time after the vehicle is shut off. A few have electric coolant pumps to continue to circulate the coolant as well to reduce heat soak.
Thx mate, Ill try to test it tmw morning by turning the engine on for a min and than turning it off. |
need to get the temp up to a certain point for that to engage. Looking at the temps where you are at, if you are in traffic it will likely warm it up enough to trip that feature
I just found out today that there was a recall on the Velar fan on excessive noise, might want to check it out at your local Land Rover
OFSA N451 coolant pump operation . check with your dealer .
