Quick Connect Trailer Hitch.
Looking for the quick connect hitch so I can start pulling my Ranger Bass Boat. PM me if you have one for sale. Thanks.
For a d1, d2, range rover?
Sorry, I forgot to list. It would be for a 2006 LR3 SE.
That's a new one on me. What's a land rover quick connect trailer hitch? The only ones I know of are for farm equipment like Farmall tractors.
http://farmallparts.com/products/photos/IHS917.jpg |
The Quick Release One, with the green key thing-a-ma-jig.
I looked it up. Bloody hell! :eek:
Take a look at Curt. CURT Manufacturing - CURT Trailer Hitch #13456 Someone on DWeb installed that PN on their '05 Discovery 3. |
Yeah, major sticker shock. I've found a generic one that bolts on that's less and if I can't find a used OEM I'll probably go with that.
I already have the remainder of the hitch so I don't really want to go with something like the CURT where I have to install an entire hitch, but thanks for the link anyway. |
Originally Posted by uoflcardfan77
(Post 523403)
If you've already got something in that location, are you just wanting a ball mount? If so you can get one at walmart for like $20. If you don't need to two much, Atlantic British has a bolt on receiver, that bolts to the frame where the factory hitch would snap in, but it's not rated for much weight. Rover Trailer Hitch Receiver - Land Rover Tow Accessories The factory receiver is rated for 7700lbs. The Curt is rated for 6000lbs. (more with WDH, but most recommend against doing that on a vehicle with air suspension.) the AB is rated for 5000lbs. I found a used factory receiver. They aren't cheap, even used you'll probably spend $300 for the newer style. If you want the older plow style, you can sometimes find them for $200. Still better than the $500 for a new one. I went that way because it's rated to tow more.... I want the option even if I don't do it often. |
I have everything but the quick disconnect part that snaps into the rest of the hitch, and then you just add the receiver part (with the ball). I found the OEM one on ebay so I think I'm going to go ahead and buy it. Like you said it's rated higher than the one that bolts on and gives me a greater margin of safety.
(Post 523427)
I'm still not sure what you're saying. do you already have this: http://www.bputah.com/LR3/Land_Range...eceiver_A3.jpg Because that's all there is to it. The part this connects to is the frame/chassis of the vehicle. Or are you looking for this: http://www.bputah.com/RR44/LRK20941.jpg Because you can get that at walmart. |
