ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
Most Capable Stock Land Rover Model?
Old 10-06-2018, 06:27 PM
nathanb's Avatar
Default Most Capable Stock Land Rover Model?
Offroad capability, in stock trim, and why?
We've seen electronics and driver's aides get vastly more sophisticated with each new generation of Land Rover model, but we've also seen increasing compromise of off-road purpose, traded-off for on-road performance, comfort, and luxury. The Discovery 2 still had solid axles and relatively high-profile tires that could be aired-down for more traction. While the LR3 went to an independent suspension and low-profile tires, it may have made up for it to some degree with an air suspension that could be lifted on-demand, and better traction control. The Discovery 2 itself compromised suspension performance compared to the Discovery 1 with a change to less flexible rear radius arms, but it may have made up for it with traction control. The Discovery 1 or D90 can easily be fitted with lockers or LSD's, but if we start modifying the vehicles, then we'd have to have some kind of limit or our comparison would be pointless.
Even with the most luxurious Range Rover models, Land Rover continued to offer increasingly sophisticated offroad capabilities for many years after it was abundantly evident the purpose of the vehicles had completely changed. Now with the latest Discovery V it seems the offroad capability in stock trim has perhaps for the first time actually declined, and the few off-road features that remain have become merely vestigial. Perhaps you don't agree.
I have heard some argue that the LR3 had greater offroad capability than a Discovery 2 when compared in exclusively stock trim. Of course, the Discovery 2 provided a much simpler path to upgrade with a modest lift and higher profile tires, but with the factory setup, some would argue the LR3 more capable.
Did the LR4 increase offroad capability? What about the V? I've heard some people argue the Discovery V is the most capable vehicle in Land Rover's current line-up. If that's so, when did the Discovery surpass the full-size Range Rover in capability?
I'm not in a market where late model Defenders were sold, but if I understand right, the redesigned "Puma" model was the first to come from the factory with traction control. That may have given the Puma the best capabilities of a stock vehicle. The triangulated 3-link rear suspension should give it a slight advantage over the Discovery 2's radius-arms. There is a difference in wheelbase, but I don't think it is clear whether a 100 inch or 110 inch wheelbase is more advantageous except in specific circumstances. Certainly, a 90 or 110 will either be at an advantage or disadvantage, but it depends on the conditions, the terrain, even the particular obstacle.
I think it would be hard to argue that the leafers with open diffs and no traction control were the most capable. While the first Range Rover was almost certainly more capable than any other vehicle for more than a decade, the Discovery almost certainly improved upon it by increasing cargo capacity and relocating the spare outside the cargo area but where it is still accessible.
So what was or is the most capable Land Rover in stock form?
Old 10-07-2018, 04:02 PM
Received 1,464 Likes on 1,195 Posts
New Disco 5 or Range River Sport
Old 10-07-2018, 05:32 PM
nathanb's Avatar
You didn't say why. I'm not familiar with the V at all. Does it really improve offroad capability compared to an LR3 or LR4? How? I was more under the impression LR was starting to give up the pretense of offroad capability. I know the V still has a low-range, but what other awesome skills does it hide?
Old 10-07-2018, 06:50 PM
Improved suspension, improved power plant over the the LR4, worlds beyond Terrain Response, and Traction control over the 3/4. Bigger wheel wells, for tire choices better brakes can order with a locker as well. Then you can get into MPG, interior refinement etc
Old 10-07-2018, 07:10 PM
stillruns's Avatar
I would gander to say the Defender, D1 and the LR3/4. The Defender and D1, and RRC all share the same underpinnings essentially. The Defender 90 has a great 90in wheelbase with great approach/departure angles. The D1 with its 100 in wheelbase good appr/dept angles (with the foglamps plastic trim removed). I believe every D1 had the lower foglamp plastic housing with or without lamps. With that removed the approach angle is excellent but is it stock? The LR3/4 have adjustable height that from what i see helps well with ground clearance, add to that improved electronic goodies and they do well off road. But, if I had to pick one, in stock form with no mods i would probably go with a D90 with terrain appropriate tires. For longer trips I would choose a D1 for comfort and off road capability. My decision is assuming we are back in 1997 when these things were new. I can’t really comment on the new V’s but all I read from forum members are problems after problems. Edit: forgot the V’s have a diesel. That would have to be a major bonus right?
Of course a 101fc would trump them all in stock form, buy they weren’t exactly available here
Edit Edit: Are we talking about having to choose one TODAY? A 20 year old D90 v. A 2018 D5?
SoCal Rob
05-29-2014 03:47 PM
binvanna
LR4
02-03-2013 06:30 PM
nevada ben
11-11-2012 10:17 AM
DonMitsu
LR4
06-28-2012 01:52 AM
gameboy2901
03-27-2008 12:06 PM
Quick Reply: Most Capable Stock Land Rover Model?
