Sights N Sounds Post Video and Sound clips here. This forum is for video's pertaining to Land Rovers, Range Rovers, and Freelanders.
Ticking noise and wandering idle
Old 05-20-2018, 02:18 PM
Biz234's Avatar
7th Gear
Default Ticking noise and wandering idle
Just got this 97 disco 1 and there's a small ticking noise coming from the engine and a wandering idle.
the guy I bought it from said the engine had been replaced and so on, but I'm not sure what's going on..
The idle almost sounds like you are accelerating and then stopping to a normal idle..
Any ideas or suggestions as to what might be happening??
Old 06-11-2018, 08:56 PM
CamelChad's Avatar
Can you post a video?
Old 07-07-2018, 03:38 PM
mr. choodles's Avatar
Without hearing the sound, all bets are off. These cars tend to make a great range of noises, especially when neglected.
Old 07-07-2018, 04:17 PM
CamelChad's Avatar
I had a similar issue. Turned out the manifold bolts to the Y-pipe were loose. Apparently it's pretty common. Should help with the tick. Idle issue is probably something separate all together.
Old 07-08-2018, 10:21 AM
Biz234's Avatar
7th Gear
I'll take a look. Thanks!
yeah I bought it from a guy who got it at an auction, so who knows how neglectedl it has been.
Old 08-14-2018, 10:11 PM
Dave03S's Avatar
Needing more info on the ticking, does the tick occur when you first start it up until it gets warm? Does it show up after it is up to temp and not while cold? Or is it present at all times? Does it go away with higher RPM's or get worse? And finally what oil are you using?
Jennyellen13
LR4
02-03-2018 11:12 AM
94svt50
03-06-2011 09:10 AM
David A
02-08-2011 09:15 AM
jr99rover
10-24-2010 09:34 PM
jck09
04-17-2010 08:20 PM
Quick Reply: Ticking noise and wandering idle
