Suspension sponsored by Arnott Inc. Talk about your suspension within.
Arnott Introduces Remanufactured Air Struts for the '13-'18 Range Rover
Old 02-03-2018, 08:29 AM
arnottdoug's Avatar
Former Sponsor
Default Arnott Introduces Remanufactured Air Struts for the '13-'18 Range Rover
Arnott Air Suspension Products is pleased to introduce a completely remanufactured OE Front Right Air Strut AS-3067 and a completely remanufactured OE Front Left Air Strut AS-3068 for the 2013-2018 Land Rover Range Rover (L405 Chassis).
Each remanufactured Land Rover air strut is painstakingly tested, disassembled, cleaned, recharged, painted, and rebuilt from the ground up. The Arnott remanufactured strut features a new multi-ply rubber air bladder manufactured by ContiTech along with new dust boots, new protective aluminum can, new heavy-duty crimping rings, new O-Rings, and new air fitting.
AS-3067 and AS-3068 are backed by Arnott's renowned Limited Lifetime Warranty and are designed to work with the vehicle's auto leveling suspension controls.
Features:
• Multi-Ply ContiTech Air Spring Bladder
• Pre-Assembled for Easy Installation
• Detailed Installation Manual Available for Download
• Engineered & Remanufactured in the USA
Additional Aftermarket Innovations for the Land Rover
The featured new aftermarket Air Struts for the Land Rover Range Rover are high-quality, cost-effective solution for Range Rover owners concerned about failing OE air suspension parts leaving them with expensive and recurring maintenance problems. 'The Arnott Advantage' adds exceptional value to some of the most sophisticated air suspension components available. In keeping with the Land Rover tradition of quality and performance, Arnott continues to introduce its own products and designs to replace failing original equipment. See Arnott's impressive array of additional, innovative new and remanufactured aftermarket replacement parts for the Land Rover Here.
arnottdoug
11-17-2017 06:45 AM
arnottdoug
07-20-2017 02:41 PM
arnottdoug
06-17-2017 12:03 PM
arnottdoug
06-17-2017 12:01 PM
arnottdoug
09-12-2014 01:08 PM
Quick Reply: Arnott Introduces Remanufactured Air Struts for the '13-'18 Range Rover
