coil conversion
has anyone done the coil conversion from the stock airbag suspension? for a 1996 RR 4.6HSE ? if so hows the ride quality. and how do you get the dash to not beep because the EAS doesn't see the airbags anymore.
Depending on the coils used, you can vary the rides based on your needs.
There are kits available, but they don't let you select the type of ride you want. If you want some help, send me your tele number and I'll call you. |
do you know of anyone who has the bypass module for the EAS ecu?
Atlantic British does and with a little searching you may find others with a better price, also try Arnott Industries, they have a good product line for this stuff.
alright thanks i'll look into that!
