lr3 suspention
lr3 suspention
hello everyone !
i got lr3 S and i love this car but i have one problem -the vichletoo low.
and i wonder if you can help me ?
i want to rase him and i want to know if you can advise me some good company who make springs to the lr3 or even conect me with a diller ?
thanks alot...
thanks alot...
RE: lr3 suspension
ORIGINAL: lior3
hello everyone !
i want to raise him and i want to know if you can advise me some good company who makes springs to the lr3 or even conect me with a diller ?
thanks alot...
hello everyone !
thanks alot...
RE: lr3 suspension
What he means to say:
Translation:
Hello everyone!
I have an LR3 SE(?) and I love this SUV, but I have one problem. The vehicle sits too low.
I wonder if you can help me?
I want to raisse him and I want to know if you can advise me on a good company that makes springs to replace the air ride suspension on the LR3 or even connect me with a dealer.
Thanks alot...
RE: lr3 suspension
the disco 3 S have air suspension, in the UK when they came out the trim was as follows
5 seat
7 seat
S
SE
HSE
but now for 2006-2007 they have changed it and included a new trim level, its now
5 seat
GS (7 seat)
XS (S)
SE
HSE
METROPOLIS LE
everything from the 7 Seat onwards has air suspension over here in the UK
5 seat
7 seat
S
SE
HSE
5 seat
GS (7 seat)
XS (S)
SE
HSE
METROPOLIS LE
RE: lr3 suspension
Lior, I will assume since you called it an LR3 and not a Disco3 that you are in the US. I am not aware of any LR3's that do not have air suspension. I was under the impresion that all LR3's have it. And as far as that goes, I have played enough with mine to have gotten into some "extended mode" times. If you have ever seen an LR3 that sits on extended mode plus the manual extended mode, it is down right high. I have a hard time understanding why you would need any more hight than the double extended mode on the LR3, specialy when you consider that you are voiding warranty when you start customising at that level. Maybe you are not aware that you do have air suspension on it or how to use it? Not pointing fingers, just courious.
on
RE: lr3 suspension
ORIGINAL: Jantiz
I know one person in the LA area who bought one, tried for quite awhile to figure out a way to raise it cause it actually sits quite a bit lower the a new stock truck with air suspension.
Any way, because of the design of the truck, especially where the axles go thru to the rear wheels, you can not do much in the way of raising them.
