18" all terrain LR3 Tires ???
Anyone recommend a good aggressive all terrain tire? Choices in the 255/60/18 are very limited . Ive read all the posts and still having a hard time deciding. I've ran bfg all terains and mud terrains on a hunting truck of mine for years with no complaints. However i cannot get this tire for my lr3 unless going up a size tire. If i decided to do this would I have rubbing issues?
Any advice would be appreciated. |
IF you are having issues finding 18' tyres , there's another alternative ( but costly ) you can get a totally different size of rim say 16's,( after market ) maybe with a taller profile tyre in off road ,
but keeping the same circumference of the 18' keeping the ratio , so when you are not going off road , you can run your 18's ,,,, to save the life of your off road tyres. ( we have this same problem here in the Caribbean ) |
I would say a great bet is the Nitto Terra Grappler or the new Nitto Grappler G2-- looks very nice. I've been using the Terra Grapplers, very happy with them. The G2's look awesome. If you want to stay with 255...
G2 *255/55R18 109H21550012.729.0210.437.0-(8.0)-9.02271@50 The wider option LT285/60R18 E 122/119S21531015.631.4611.508.0-(8.5)-10.03305/3000@80 Also the TG have sizes for you. Very rugged. If you want a taller profile, you'll need toddco spacers and / or lift rods, etc. Overkill IMO. You can see the Nitto Terra Grappler 285/60/18 here, under Rover Specialties. You can also get 17" rims from Justin at Lucky8 if you want to go that route. |
Originally Posted by WoodlandsLandRover
(Post 513652)
Any advice would be appreciated. I faced a similar problem and fitted two General Tire AT2 Grabbers 255x60x18. I am going on an extended trip into the desert so hope they perform OK. The decision to replace only 2 tires was based on the fact the other 3 were in good condition. If you need to change all 5 tires then go up a size to 265x60x18 since there are more supplier options. Tadpole 07 LR3 SE TDV6 |
I am doing my suspension now, I have 18" and 19" rims I want e rated tires and can't find any in Rover sizes
If I can't get e I at least want something heavy duty, after all it is a 7100# truck |
Originally Posted by justryan
(Post 513720)
but keeping the same circumference of the 18' keeping the ratio , so when you are not going off road , you can run your 18's ,,,, to save the life of your off road tyres. ( we have this same problem here in the Caribbean ) Tom, I just ordered 255/55R19 in a MT. More info on them in my DII build thread. |
I realy only want all season tires, a/t if I have to
That's no fun....
Nope, its her work get to work truck, is the XL rating like e?
I believe so. You might check Goodyear they had a Adventure Kevlar AT in 255/60R19 it didn't look very aggressive though. They also had the Duratrac in a 255/55R19.
