Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Tire rub damage
Old 04-24-2018, 02:53 AM
bradbishop's Avatar
5th Gear
Default Tire rub damage
My 2008 LR3 has had Nitto Terra Grapplers (285/60R 18) for years now. I always knew they rubbed in a little under certain conditions but the damage to the tires I'm seeing looks worse than I would expect.
I'm having some body/suspension damage repaired (unrelated to the rubbing) and the body shop that found the wear says it comes from contact with the knuckles. The tires have about 35K mileage on them.
Anyone have any experience with this--is this wear acceptable or should I replace the tires? Thanks
Old 04-24-2018, 06:46 PM
Fastercat's Avatar
To me it looks bad. I’d replace them to be safe. Would small wheel spacers keep them from rubbing? Might be worth checking into.
bradbishop (04-24-2018)
Old 04-24-2018, 09:00 PM
bradbishop's Avatar
5th Gear
Yeah, that's what I thought, too. Was thinking of switching them out for 265's instead of 285.
kato disco
03-08-2011 03:06 PM
oysterhead
12-30-2009 05:32 PM
oysterhead
08-23-2009 10:19 PM
ScottinNJ
Tires
11-11-2007 06:56 PM
RoverDude420
11-18-2005 01:02 AM
Quick Reply: Tire rub damage
