Rims
hey guys, I know this section is about tires but just in case someone knows. I have a set of rims with corrosion on the inside of the rims. I was looking into having them repaired. One specialist said he could not address he corrision because afterwards the wheels would not sit correctly on the car. another specialist he could sandblast the corrision off without any issues. Thoughts? https://cimg7.ibsrv.net/gimg/landrov...7a87b227c.jpegCorrision |
Did you pull this thing out of a lake? Where does that type of corrosion occur?
If it was setting against a drum there would be nothing on the centre part of the wheel. |
Originally Posted by Aj6543
(Post 646308)
One specialist said he could not address he corrision because afterwards the wheels would not sit correctly on the car. another specialist he could sandblast the corrision off without any issues. Thoughts? Corrision |
You could probably get them machined, but then you are cutting into metal and weakening the structure. I would not trust those rims.
Originally Posted by Art H
(Post 738650)
It was 2 years ago
