Arnott Introduces New Front Air Struts for '06-'09 L322, MK-III and Vogue
Arnott Air Suspension Products -- the leader in aftermarket air suspension parts and accessories -- is pleased to introduce Arnott-designed new Front Air Struts for the 2006-2009 Range Rover L322, MK-III and Vogue (Supercharged Only). Arnott Parts AS-2795 (Right Front) and AS-2796 (Left Front), are new and not remanufactured.
The new aftermarket Air Struts for the Range Rover retail for $449 each and replace OE Part Numbers:
Front Right:
LR032563
RNB501520
RNB501400
RNB501340
RNB500540
Front Left:
LR032570
RNB501530
RNB501410
RNB501350
RNB500550
Arnott's exclusive design features a new custom-made and tuned shock absorber valved to provide an excellent ride. The Air Struts are assembled in the USA with a multi-ply air spring bladder manufactured by Vibracoustic. The strut assembly also features extra-heavy duty crimping rings, new seals, new air fitting, new check valve and a stamped steel top. This Arnott-designed new Air Strut assemblies are backed by Arnott's renowned Limited Lifetime Warranty and 30-Day Return Policy.
Features:
* Custom-Designed Twin-Tube Shock
* Vibracoustic Multi-Ply Air Bladder
* Black Anodized Stamped Steel Top
* Heavy-Duty Crimping Rings
* Limited Lifetime Warranty
Additional Aftermarket Innovations for the Land Rover
The featured new aftermarket Air Struts for the Land Rover Range Rover are high-quality, cost-effective solutions for Range Rover owners concerned about failing OE air suspension parts leaving them stranded with expensive and recurring maintenance problems. 'The Arnott Advantage' adds exceptional value to some of the most sophisticated air suspension components available. In keeping with the Land Rover tradition of quality and innovation, Arnott continues to introduce its own products and designs to replace failing Land Rover original equipment. See Arnott's impressive array of additional, innovative new and remanufactured aftermarket replacement parts for the Land Rover Here.
Front Right:
LR032563
RNB501520
RNB501400
RNB501340
RNB500540
Front Left:
LR032570
RNB501530
RNB501410
RNB501350
RNB500550
Features:
arnottdoug
07-27-2017 05:00 PM
arnottdoug
07-20-2017 02:41 PM
arnottdoug
06-17-2017 12:01 PM
arnottdoug
09-12-2014 01:21 PM
arnottdoug
09-12-2014 01:08 PM
