Arnott Introduces New Front Air Struts for '06-'09 L322, MK-III and Vogue
Arnott Air Suspension Products -- the leader in aftermarket air suspension parts and accessories -- is pleased to introduce Arnott-designed new Front Air Struts for the 2006-2009 Range Rover L322, MK-III and Vogue (Supercharged Only). Arnott Parts AS-2795 (Right Front) and AS-2796 (Left Front), are new and not remanufactured.
The new aftermarket Air Struts for the Range Rover retail for $449 each and replace OE Part Numbers: Front Right: LR032563 RNB501520 RNB501400 RNB501340 RNB500540 Front Left: LR032570 RNB501530 RNB501410 RNB501350 RNB500550 Arnott's exclusive design features a new custom-made and tuned shock absorber valved to provide an excellent ride. The Air Struts are assembled in the USA with a multi-ply air spring bladder manufactured by Vibracoustic. The strut assembly also features extra-heavy duty crimping rings, new seals, new air fitting, new check valve and a stamped steel top. This Arnott-designed new Air Strut assemblies are backed by Arnott's renowned Limited Lifetime Warranty and 30-Day Return Policy. Features: * Custom-Designed Twin-Tube Shock * Vibracoustic Multi-Ply Air Bladder * Black Anodized Stamped Steel Top * Heavy-Duty Crimping Rings * Limited Lifetime Warranty Additional Aftermarket Innovations for the Land Rover The featured new aftermarket Air Struts for the Land Rover Range Rover are high-quality, cost-effective solutions for Range Rover owners concerned about failing OE air suspension parts leaving them stranded with expensive and recurring maintenance problems. 'The Arnott Advantage' adds exceptional value to some of the most sophisticated air suspension components available. In keeping with the Land Rover tradition of quality and innovation, Arnott continues to introduce its own products and designs to replace failing Land Rover original equipment. See Arnott's impressive array of additional, innovative new and remanufactured aftermarket replacement parts for the Land Rover Here. |
