If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
For the price, durability, function and application method, I am searching bedliner spray .I HAVE SEEN MANY BRAND NAME LIKE QWIKLINER ,LINE-X,ETC.WHICH ONE BETTER
show me the picture after the spraying the bedliner.
Sometimes back I got my truck sprayed on with Spray on bedliner of Qwikliner.It took only few seconds to set & the quality of finish is awesome. I will definitely recommend qwikliner bed liners.
I like Qwikliner it has a texture that is non-slip, but yet it is not rubbery, so if you are using the truck to carry dirt/mulch/gravel, like you would with a truck it is a very good surface to shovel and sweep stuff off of...
Wow, went through a lot of trouble to hide in different accounts to promote a product that has virtually no application in this forum.
PS, line-x is the best I have used. Quickliner does not stick to the bed of a truck. It peels off in sheets.
__________________ RAVE Good Oil
2003 Range Rover HSE with 2008 trim
2010 GLK 350 Mercedes
1990 VW Cabriolet - Lake car...
1997 Discovery SD-7 to put the boat in.
I have qwikliner in three truck beds and feel that it is a better product than others. It seems to be tougher. However, the key to getting a good spray-on bedliner is the installer. If they cut corners, or don't know what they are doing, you can get a lousy job from either brand. Look at some trucks the installer has done before you let him do one for you. Look for clean edges, a good thick even coating, even texture, and make sure they take out any and all bolts, nuts or other removable parts before they spray the Qwikliner on.(Like bolts and cover plates that access tailgate latch linkages) If they have sprayed over this hardware it is a sign that they are doing a quick, cheapie job, AND, you will never get it apart if you need to. A friend of mine is in the business and pointed out to me how to spot these signs of a cheap spray job
I bought my truck and immediately had a QWIK Liner put in. Well, that lining paid for itself after just one trip.
After work I set my toolbox at the edge of the bed and drove home - several miles of twists, turns, bumps and hills. When I went to unload, I saw I'd left the tailgate down. I was sure my tools were gone. Instead, they were right where I left them - as if they were glued down. I've bragged how tough and good looking my QWIK Liner is
anyone think there is a way to rip up the carpet in the back of a disco and spray down some bedliner? I would love to make it more durable for when im loading and unloading stuff. i would want something i can spray or roll on myself though.
__________________ -Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
