Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
using stock amp with amp integration harness
Old Apr 29, 2007 | 08:04 PM
agentmilo's Avatar
4th Gear
Default using stock amp with amp integration harness
i bought an aftermarket deck to install in a 1998 range rover. there is a stock deck running all the speakers. i bought a wire harness and it came with an amp integration harness which has 4 rca connectors on it. i connected it to my deck and hooked up the remote wire of the stock amp to the remote from my new deck. when i turn it on there ismusic comingoutbut there is also a very loud high pitched humming sound that i cant get rid of. any suggestions?
Old May 3, 2007 | 02:22 PM
agentmilo's Avatar
4th Gear
Default RE: using stock amp with amp integration harness
the problem seems to be that when i try to manually turn on the stock amp using the remotewire coming off itthere is some sort of feedback or interference and i get this high pitched sound on my speakers even if the deck and car are both off.
Old May 3, 2007 | 02:28 PM
wease206's Avatar
try a noise filter if that does not work then you might have to run it with the amp and it is pretty easy to no the door is were the amp are locted at each door has one and go out and buy a new amp you will have a amp sound
Old May 4, 2007 | 06:41 PM
agentmilo's Avatar
4th Gear
i tried a noise filter and it didnt change anything. how can i bypass the amp and wire the speakers directly to the new deck, i guess this amp integration kit was a waste.
WaltNYC
Apr 2, 2018 01:29 PM
derekschmiedl
Jan 22, 2009 11:12 PM
dhlair
LR2
Aug 20, 2008 02:04 PM
AussieDom
Jan 9, 2008 07:04 PM
