Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Harmon Kardon?
Old May 24, 2007 | 12:13 AM
Nokeman's Avatar
Default Harmon Kardon?
Does my 03 Disco SE have the Harmon Kardon stereo system in it? The dealership told me it did. Are they lying to me?
Old May 24, 2007 | 01:27 PM
Randy Lover's Avatar
Default RE: Harmon Kardon?
you will know if it has the harman kardon installed. if it has the Harmon Kardon badge on the mid range drivers on each front door you have them. if the speakers are blank he was probably lying. and also if your in the UK the SE spec has the Harman Kardon
Old Aug 12, 2007 | 04:15 PM
robross's Avatar
Speaking of the Harmon Kardon stock system, does anyone know where to get the technical specs for it, or have any input for an easy way to wire an amp and subwoofers to the stock setup?
Old Aug 13, 2007 | 06:18 PM
fire1427's Avatar
the EASIST way is to get the low level convertor from a stereo shop then connect that into the rear existing sub wires, run RCA's from it to the "new" sub amp , run power ground to the amp ... IF you have the amplified rear subs you can tap there for the remote line to the new amp ...
yarddawg
Jan 28, 2008 04:02 PM
wblake
Nov 3, 2007 08:19 AM
ajh
Oct 21, 2007 05:59 PM
kay
Dec 9, 2006 03:37 AM
Crusoe
Apr 8, 2006 10:28 AM
