Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
How do I get into instrument panel to replace bulb
Old May 8, 2010 | 03:16 PM
SC Rovergirl's Avatar
Default How do I get into instrument panel to replace bulb
There is a bulb that illuminates the odometer that is out and I need to know how to get into the panel to replace, I didn't find instructions in the Rave Manual.
Old May 9, 2010 | 06:01 PM
03discoman's Avatar
I don't know what model yopu have but ussally you remove the two peice cover that makes up the steering colum cover . After you remove that you take off the plastic cover of the ip cluster, some screws...and then your at the cluster.... 2 screws. On each side
Old May 12, 2010 | 07:00 AM
hilltoppersx's Avatar
there are two screws right behind the wheel above the steering column. undo those. pop out your swiches on both sides and disconnect the wiring harness make sure to write what color is for what switch. there are two tabs holding the console cover down. should pull striahg tforward. you will see 4 screws holding the console down. undo those 4. theh plastic cover comes off with 5 tabs holding it to the speedo. there are two more wiring harnesses holding the speedo into the ecu. disconnect both. a few m0ore tabs hold the back on pop those off and you will have access to the bulbs. there are four bulbs. three white and one blue. the blue is your high beams the whites are your main back lights. good luck
Kordian
Mar 18, 2015 06:06 AM
Street Wolf
Jan 20, 2012 08:04 AM
Classklown90
Aug 21, 2010 07:24 PM
litterlout
Aug 27, 2006 11:16 AM
James Vee
Feb 1, 2006 10:34 AM
