Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Stock Subwoofer install
Old Dec 2, 2010 | 06:41 PM
losinov's Avatar
Default Stock Subwoofer install
Hey guys just looking for some help with the install of new 6 1/2 inch subwoofers. So I removed the two old subs from the rear door today since the new ones just came. So the new subs have two spots to hook up the wires from the amp (pics below). I am guessing that I can pick either connection and there are two just for convenience of hook up. Here are the specs of the new subs:
Specifications::
Power Capacity: 45W/60W RMS/peak
Sensitivity: 89dB (W/M)
Impedance: 4ohm
Re: 3.5ohm
After re mounting the amp in a new spot in between the subs I will just connect the black and white into the + and the all black wire into the negative. You guys think I should solder them or twisting it in will be okay? Thanks for any help
New Sub:
Old subs:
Old sub close up:
G150driver
Apr 21, 2015 02:00 PM
Reesie
Aug 15, 2013 04:29 PM
DiscoSux
Nov 17, 2010 09:46 PM
2002DiscoII
Jan 9, 2006 09:10 PM
