Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Audio/Visual Electronics
Register Forgot Password?
Old 12-02-2010, 06:41 PM
losinov's Avatar
Senior Member
Location: Mountains of blacksburg during the school year and northern VA during the summer.
Send a message via AIM to losinov
Default Stock Subwoofer install
Hey guys just looking for some help with the install of new 6 1/2 inch subwoofers. So I removed the two old subs from the rear door today since the new ones just came. So the new subs have two spots to hook up the wires from the amp (pics below). I am guessing that I can pick either connection and there are two just for convenience of hook up. Here are the specs of the new subs:
Specifications::
Power Capacity: 45W/60W RMS/peak
Sensitivity: 89dB (W/M)
Impedance: 4ohm
Re: 3.5ohm
After re mounting the amp in a new spot in between the subs I will just connect the black and white into the + and the all black wire into the negative. You guys think I should solder them or twisting it in will be okay? Thanks for any help
New Sub:
Old subs:
Old sub close up:
__________________
1994 5MT Land Rover Discovery (155k) - 60K service list complete, Head Gaskets and all other gaskets replaced, new steering box, window ECU fix, door latch springs, wink mirror, cup holder
Tags
1994, 94, discovery, hooking, install, land, range, rover, specs, stock, subwoofer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
