Defender Talk about the Land Rover Defender within.
Best engine oils for 3.5L V8 Defender (1991)
Old Jan 20, 2009 | 12:52 PM
jameswarwick's Avatar
Default Best engine oils for 3.5L V8 Defender (1991)
I own a 3.5L V8 Defender (1991) out here in Kenya - which engine oils would you recommend I use? I have always used Shell Helix Ultra 15W50 but they've changed it to 5W40 now - is this still OK and a good oil to use for this engine? Thanks for your help!
Old Jan 21, 2009 | 10:14 AM
Adz's Avatar
Adz
Default RE: Best engine oils for 3.5L V8 Defender (1991)
I'm no expert on V8's but that engine is essentially the same as the one used in the early Discovery 1 and in the Range Rover classic - you should be able to find plenty of information in both the discovery and range rover sections of the forum. Good luck
archaeology_student
Aug 31, 2013 02:50 PM
thehun
Aug 24, 2011 09:52 PM
okdiscoguy
Aug 3, 2007 06:16 PM
johnnybob06
May 14, 2007 11:31 AM
